Old Dec 1, 2006 | 09:28 PM
dynamicS's Avatar
dynamicS
Default Re: Calipers for an amg E55
Originally Posted by feets
I finally got a few minutes to kill at work and took a tape measure into the warehouse. The SLK 230 has the same size brakes as the Limited. Nothing to be gained there. The SLK 320 has the bigger discs. Obviously, the SLK 32 has the good stuff.
Those monster E55 brakes are a wee bit heavy. The calipers really don't weigh much more than a smaller cast iron or steel caliper. The aluminum really helps. However, the rotors are 27 lbs each. That's ugly. The flip side is that you've got MUCH more braking force to slow down the rotating weight.
Should you be working on a purpose built car with custom tailored suspension, the unsprung weight will cause you to rethink your spring and damper rates.
Ahh good to know, I see I had it mixed up between the 320 and 230, damn you dyslexia!
Feets, If you can get a chance, what does your dealership charge for the SLK320 rotor, caliper, and anchor assembly? How much larger is the diameter of 320 rotor compared to the Limited rotor?
