Originally Posted by andrew
the springs are seated/locked in the perch... even on a lift the spring shouldn't be loose.
i don't think the springs would be the issue... i had them installed on your car... and it was done correctly.
i would have the tire company remove each rim and look for any signs of issues... re-install the rim and re-torque.
hope this helps!
Andrew: I didn't know you became a mechanic as a sideline... LOL.
Check to see if the inside shoulder of the tire was rubbing on the A frame bolt...
PS: just arrived in New Orleans and it looks like the internet on my blackberry is kind of working on this oil rig.
