Thread: 6th in '06
Old Dec 22, 2006 | 05:12 PM
HDDP's Avatar
HDDP
Default Re: 6th in '06
Thanks guys... I didn't think I would place that well since I missed a few events due to work. Now, with the 2007 rule changes that bump me to TTC class, I have to figure out which additional modifications will benefit me without bumping me up another class...
I'm thinking cheap first... I'm going to reduce more weight by cutting the door frames, hood frames and remove the hood hinges. I'll also cut the rear hatch framing and replace the glass with lexan. If I can reduce another 150 lbs, I'll be happy. Also, I'll probably install the Schrick cams and have the custom headers built now. If I had more time I would try to get that SRT6 engine I bought (minus SC) installed...
I still have to compute the current modification points that I have been assessed under the 2007 rules to see where I'm at, before I dive into this thing...
I'll keep you all posted... It's going to be a bit crazy for me since I have to temporarily move to South Carolina on February 14th.
