Re: WOW ... stop the rust while you can ...
Took the cover off my stored 05' roadster (900 miles) late last night and saw some beginning signs of the moisture problem. Have to believe this is common on most of the crossfires as it obviously traps the moisture. You would think a car sitting on dealer's lot for seven months would be "clean", but not the case. I will treat with POR15 soon. I noticed that my door seal has drain holes in it, but obviously doesn't alleviate problem. Is there a technique involved to re install the seal to secure it as tight as it was when I pulled it out? Thanks Andrew for bringing this to our attention, great info! Happy Holiday's.
