Old Jan 10, 2007 | 08:02 PM
BRappaport's Avatar
BRappaport
Default Re: P0410 code check engine light
Originally Posted by 04-hellfire
I've had my car checked with obd11 scanners came back with code P0410 secondary air injection pump. The check engine light goes off and comes on it was off for 3 days and then came on and would not go out. Has anyone had this problem?
I had the exact same problem...with check engine light and code...it was a bad gasket on the pump...you could actually feel the air coming out of the pump. The pump was replaced at 4,500 miles under warranty. Easy and straight forward ...but they had to order the pump, which took about a week. This is the third occurrence of this that I have seen on this forum.
