Old Jan 12, 2007 | 11:53 AM
04-hellfire's Avatar
04-hellfire
Default Re: P0410 code check engine light
Originally Posted by woody
Code P0410 relates the air pump that injects air into the exhaust manifolds during engine warm up. It is located on the front of the engine and only runs for about a minute when the engine is started from cold. Code P0410 is thrown if the ECU fails to detect the pump in circuit so I would check the single two-pin connector that feeds the pump, and from memory I think there is a single fuse in the fuse box that feeds it which is also worth a look. It sounds like you have an intermittent connection to the pump. Have a look here for more details.
I have checked the pump it is working fine and the connections to it are clean i tried to trace the wire back to its source but none of the wires seem to match the one connected to the pump which seems to have led into that junction box on the passenger side of the car my idea of course would be to look at the relay or any other connections if I could locate it. Any ideas or suggestions.
