Old Jan 15, 2007 | 03:04 AM
  #41 (permalink)
JP@SI's Avatar
JP@SI
Default Re: Ecu Tuning: Crossfire Ecu Tune! Ny/ct/pa/nj
HDDP although you are the moderator on this forum we don't appreciate the negativity that you bring to this thread. I am sure the engineer that "supposedly" tuned your software is the best that you could get a hold of/friend. By the way you speak you have very little knowledge of software tuning and our capabilities with Mercedes.
Do you know what a "DAMOS" file is or what it does? Do you understand the capabilities of a DME? Why would you use an FMU when all fuel maps are fully adjustable and can be modified to correct afr at any point in the rev range of the engine. Do you understand how to tune a mercedes?
You're so quick to name ebay as a source of files for the companies such as Powerchip, Superchips, SpeedInnovation, etc.
Why, did you yourself try to become an ebay tuner/ crossfire tuner?
HDDP, first and foremost your so called "Bosch engineer" that tuned your car... is he willing to be named or show up for a shoot out. I believe he wont (which questions if your car is even tuned) maybe it came from fleabay. You don't even have a dyno for your car to show your engine tuning.
So, you see negativity can go both ways as well and honestly we will provide a free custom tune as long as the vehicle we tune will compete with your dyno results. So basically, your car will be untouched and a forum member here will receive a free tune.
Secondly, What's your mod list so we can find a member here that is as close to modified as yours (therefore, it can be fair). Or do you want us to provide a crossfire with SpeedInnovation modifications.
Do you want to do "power testing" only or you want to take it the track as well? We also have access to a fully prepped crossfire that will be shipped to us for tuning. HINT: Its making a lot of power (without tuning), right now its very lean and had a lot of engine work... lets say its built to rev...
Btw, those 'brabus' wheels on that crossfire race car is a good way to add a lot of weight. Real brabus monoblock 6 two piece wheels are bricks.
Edit: Wait... 192 WHP w/ 'tuning right? https://www.crossfireforum.org/forum...05&postcount=6
You know a 3.2L Mercedes Motor with just K&Ns can put 190 WHP?
