Removing the Ignition key assembly
I am trying to remove the ignition key assembly from the steering lock. I have the transponder coil off the ignition switch cover sleeve. Now, how do you get the sleeve off the lock so you can remove the key assembly?
I am sorry to bother you, but I am stranded in Florida and need to get it started or I will have to get it towed 20 or more miles.
