Old Mar 3, 2007 | 11:42 AM
intenseblu's Avatar
intenseblu
Default Re: interest in a real cold air intake system ?
the idea is not to get different air at all... just more of it... it is true we do have a CAI but it is also extremely restrictive which results in a ultra quiet intake system + low end torque + choked top end power...
by utilizing a venturi based system with conical filters i can introduce air on a 360 degree field in the same physical space the current restrictive panel filters take up ... the venturi further helps air to be literally squeezed into each other ...
don't be mistaken, this will not be a warm air intake ... the filters will be shielded from engine heat and have routing to the outside for cool air supply just as the stock setup does now.
i fully intend to have proof of power gains if i end up selling it to forum members .... as mentioned $400 - $500 is alot of money to crossfire owners but do not think of it as "i'd rather spend it on the SI chip tuning" because that will work very well with a better intake design together and we can't expect everything to give us 20 hp for $400 - $800 like the ECU retune... so think of it as another thing you can possibly add to the first mod you'll do which is the ECU retune...
