Old Mar 11, 2007 | 04:52 AM
+fireamx's Avatar
+fireamx
Default Re: Transmission Maintenance?
Originally Posted by GatorLCA
What about for manual transmissions? The manual states there's about 1.7 qts of it in there.
Since the manual tranny uses straight weight synthetic engine oil, and it's in a hermetically sealed environment, and all it does is lubricate gears, you should be able to go quite some time before changes. Unless of course you "grind" your gears on a regular basis. Then you may want to change it more often.
I believe the automatic trans uses automatic trans fluid, and I would buy it only at a Chrysler or Mercedes dealer. (Their specific brand name & part #).
A while back, Chrysler was having some problems with their overdrive trannys, and I heard they were blaming it on people not using the correct fluid, and not changing it enough. I'm sure "Feets" probably knows the whole story on that.
