Re: WOW ... stop the rust while you can ...
Yes I coated the inside of the holes drilled, the drilled holes in the rail do not go thru the door itself just the rail that only supports the weather stripping(weep holes are a better wording) you"ll see and understand once the weather stripping is removed on your crossfires. Good luck and check your door bottoms.
178
