Old Mar 18, 2007 | 10:42 PM
McCombcliff's Avatar
McCombcliff
Default factory nav install question
Hi,
I'm trying to install a factory nav radio into my wife's 2005 limited. I already purchased the head unit on ebay and it came with nothing else. I purchased the disks and need to purchase the GPS antenna from a dealer. I have read ALL the posts on how to do this, but I need more specifics.
I assume the GPS antenna just plugs in to the back of the radio...I have read posts that recommend it be mounted inside the dash compartment by accessing the right side airbag panel...is this correct?
I have read that in addition to the standard radio plug ins that 1) wheel speed sensor and 2) reverse wires need to be hooked up. Can anyone explain in detail how this is done? Is there a wire there that is bundled? or do I have to actually run a wire or wires.
Honestly, I'm a dolt when it comes to this...so can you be REALLY basic. Do I splice? If so, how and where?
Finally, How do I connect these new wires to the radio itself? I've accessed the amp in the footwell and all I see are bundles of wires and none of them seem to correspond with the speed sensor (green with white trace) color.
Lastly, where do I find the reverse wire? and how do I connect it to the radio?
If anyone can help with this I'd be very grateful.
Thanks,
Cliff
