Re: Yet another dealer service rant...
I just got my car back from dealer last night.
To "fix" the blinking light and check engine problem they did the following:
Checked evap system for leaks - none found
Replaced Fuel Sensor
Replaced Filler Cap
To "fix" my hatch not locking/unlocking:
Checked hoses - found one was pinched
Replaced hose
It was nice that they washed the exterior and cleaned the interior. I was glad to get my car back.
I went to get my emissions inspection this morning and they checked the ODB and it passed.
From there the problems started to appear:
I was on my way to work and the blinking gas light and check engine light had come back on.
After closer inspection, I also noticed the rear trims were not properly aligned. I could tell because around the small back windows there is a gap between the dark trim and light trim, where before it was flush. Also it looks like the back rear trim is also misaligned because the trunk latch is denting it and making a weird noise when closing. I think this is why they turned-off my autolight, because when I turned it back on, the light would stay on instead of dimming after a couple seconds.
Also, I still get a lot of wind noise. I think their initial "fix" for it actually made it worse.
HELP...what should I do? Should I bring it back to the same dealer and get them to fix it, or should I try to go to a different dealer? I am in the MD area. Any suggestions?
