Originally Posted by Cyril Baldwin
WARNING: DONT REMOVE YOUR BATTERY TERMINALS! It may be a myth that your car won't start if you removed them but I won't risk it at all
The very first instruction in the Crossfire Manual for the removal of the Powertrain Control Module (Their name for the ECU) says to disconnect the negative battery terminal......
I am in the computer business, and have no fear of removing the ECU, or even unsoldering and resoldering the chip. My concern is what do I do if I get it back together and it doesn't work. I am worried that finger pointing will start to happen. D/C says it is Upsolute's problem, and Upsolute says it is a D/C problem, and I am in the middle with a bobbymobile....
It may be worth a 3 or 4 hour drive to have them do it directly at an Upsolute dealer.
