Originally Posted by blacken
Ok, so I installed the driver side HID lamp today and it looks like it is pointed to low. I installed the bulb the same direction as the old one that came out. The clip looks to be in properly, I'm not even sure you can put that thing on wrong. Do you think the bulb is upside down? Does anyone know whether the support metal on the actual bulb is closer to the ground or not?
the bulb is not fully seated ... a common issue when changing bulbs...
seems as if its in place but most likely isn't.
it can be very hard to see (done by feel)... but remove the bulb and try to re-install it.
cheers!
