HID Problem
Old May 3, 2007 | 10:46 PM
blackNJ's Avatar
Default HID Problem
Ok, so I installed the driver side HID lamp today and it looks like it is pointed to low. I installed the bulb the same direction as the old one that came out. The clip looks to be in properly, I'm not even sure you can put that thing on wrong. Do you think the bulb is upside down? Does anyone know whether the support metal on the actual bulb is closer to the ground or not?
Old May 3, 2007 | 10:54 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: HID Problem
the bulb is not fully seated ... a common issue when changing bulbs...
seems as if its in place but most likely isn't. it can be very hard to see (done by feel)... but remove the bulb and try to re-install it.
cheers!
Old May 4, 2007 | 12:28 AM
snowtop57's Avatar
I just did the same thing last week, the drivers bulb was too low and the passenger bulb was pointing up & to the right. Took the mount and reseated them and now all is good. But these bulbs sure are a PITA.
Old May 4, 2007 | 10:04 AM
blackNJ's Avatar
Wow they must be. Right now I have only one in because I wasn't sure if something was wrong. I'll attempt this again after work and post an update.
Old May 4, 2007 | 09:02 PM
blackNJ's Avatar
I reinstalled them, now I am playing the waiting game until its dark to see if I did it right. Hopefully it's good.
Old May 6, 2007 | 03:32 AM
blackNJ's Avatar
OK, so one on the bulbs got stuck in the headlight but with the help of a friend with really big pliers I got it out. The bulbs are installed and point correctly on the road. I purchased 6,000k which is a little too blue for me, I may just buy 4,300k bulbs instead. They are a huge improvement over the stock bulbs though.
Old May 6, 2007 | 02:14 PM
snowtop57's Avatar
I have the McCulloch 6,000k kit, I also think the lights are a little too blue, I was wondering if I could just replace the bulbs with the 4,300K or 5,000k or do I have to buy a whole kit to do this?
Even at 6,000k I can see a lot better, probably will never have to use the high beam setting.
Old May 6, 2007 | 07:04 PM
andrew's Avatar
Thumbs up Re: HID Problem
Originally Posted by snowtop57
I was wondering if I could just replace the bulbs ... or do I have to buy a whole kit to do this?
~ yes... you can just buy the bulbs to make the needed color (k) change.
Old May 7, 2007 | 04:49 AM
bobs's Avatar
This question has been on my mind lately as well. Do you have a good source for just the bulbs? I was thinking about preemptively ordering a replacement bulb to have on hand few when one blows.
Old May 7, 2007 | 08:54 AM
WildChild's Avatar
I got mine from HIDKING on Ebay... They work pretty good. But I wonder if they are not as bright as say Phillips or McCulloch. I always see other cars with HID and some seem unbelievably bright, still the 6k color but way brighter then mine. =(
Old May 7, 2007 | 09:28 AM
andrew's Avatar
the 'service life' of an hid bulb is: 3,000 hours.
i have found replacement bulbs for: $99 - $200 per set.
http://www.advantagewholesaler.com/hidrebu60h1.html
tcar32909
Aug 1, 2024 02:41 PM
nataliefs
Oct 5, 2015 01:03 PM
AlbertFattal
Sep 24, 2015 05:03 AM
Den656
Sep 23, 2015 12:27 PM
skeet370
29
Sep 18, 2015 05:53 AM
