Re: Trunk wouldn't unlock!!
I have experienced this problem also. Usually if I hit the unlock twice on the keyfob the trunk unlocks. Every once in a while it fails to work though... I have found that if you push down on the trunk a little (read...forcefully!) and hit the unlock button another 2 times it usually works fine.
It's annoying as hell...but not enough so that I want to give the car up to the dealer for god only knows how long!
If you do have this problem repaired I'd be interested in knowing what the fix/problem was!
