Old May 26, 2007 | 07:35 AM
bobs's Avatar
bobs
Default Re: Can you re-program and re-key an existing unit
Yes, there's a way to make the car learn about a new key. Give me a few minutes and I will look it up. Not sure about getting a new one cut, but a good locksmith should be able to do it for you...
Edit: Here you go:
From the service manual page 8N-37:
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry (RKE) Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
1. Press either the lock or unlock button momentarily twice.
2. Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
