Thread: * BlueTooth * ?
Old May 28, 2007 | 04:39 PM
JimNicholson's Avatar
JimNicholson
Default Re: * BlueTooth * ?-Help/ Advice needed
Originally Posted by blacklimitedcoupe
It wasn't exactly difficult to install, just time consuming. However, after doing it once, it would be much easier. If you decide to install it, let me know and I can run through the steps with you. If you need pictures of anything I'll post them. I ordered my Motorola IHF-1000 on ebay, brand new sealed package for $184 shipped. I think best buy gets around $400 for it. The wiring harness from Becker was around $20.
- I tried installing the Motorola kit today and had to back out. Need some advice... Where did you route the power from and the ignition to? How did you make the connections because it seems the only way to make them is wire lugs to tie wire together and I do not want to do that with the car (tacky). Just FYI I am electronics savvy and have crimpers, pins etc... Just curious how others tied this in. If there are some lessons learned that I could use so I don't repeat mistakes... Thanks!
