Re: Mechanical problem - ideas wanted
Have them test the Transmission Control Module (TCM). Mine was faulty and when they replaced it, all the problems with low RPM's went away and the car has been fine ever since... now mind you, it took them over 4 months to find the problem. If its the TCM, the error codes will not be documented in the computer, as there is a disconnect somewhere.
Good luck...
