Old Jun 5, 2007 | 01:10 PM
Default Re: It finally happened, my cup holder broke...
Originally Posted by AMGLover
Poor pubba-wooba... come here n get a big huggie! Now snap out of it before you get a conga line bit*h slap!
Premature deployment can be caused by the following factor, the base of the cup holder assembly is no longer level. Take your deployed member and gently pull back on it, you may get a light thunk or pop. An early symptom of this is visible when you stow the holder and the front will not sit flush with the rest of the trim and will actual be slightly lower. Try it...
If BigPapa keep this up, we're going to have to cal the Waaambulance.
