Old Jun 6, 2007 | 12:58 PM
Sidez's Avatar
Sidez
Default Re: SRT-6 Turbo problem?
Originally Posted by AMGLover
Actually... the failure of the intercooler has 0 to do with engine temp or any type of cooling. Compressed air gets hot - hot air has excited molecules that occupy more space and hence is less dense. Less dense mean less oxygen in given volume, hence smaller bang in cylinder. The only function of the IC is to make the air denser after the SC. Due to the SRT-6 having additional programming in the ECU for the fuel air mixture/spark timing when the FAR (fuel air ratio) is out of range the ECU switches things off until the FAR gets back in range.
dreamSRT do some research on AMG and Mercedes-AMG to out find more about this badly misrepresented tuner car.
yea your right, nice to learn something new... but even if I knew exactly how it worked I probably would not explain it in such detail... either way what the IC pump will disable you from stable acceleration, but will not cause much engine damage...
