Old Jun 20, 2007 | 02:05 AM
fflores's Avatar
fflores
Default Re: JVC KD-NX5000 in Crossfire
Originally Posted by ashwats
Wow... i would really appreciate if you can take pictures through out the project and post it here. I believe the GPS need some kinda interfacing with the vehicles speed sensor? And there is an antenna for GPS to be installed under the dash? Are you planning to install a rear view cam? I wish JVC makes a Silver faced one too...
Sure, i'll take pics... yes you usually have to hit a speed sensor wire, If that becomes a problem then i'll just take it to a audio shop. Here is a question, when you have a stock GPS navi from chrysler, i am assuming that the harness that connects to the back of the GPS HU has the speed sensor already hooked into the stock harness...
As for the GPS antenna i will see where i can hide it, i do not want to put it on the exterior of the car.
Should be here on Monday.
