Old Jun 26, 2007 | 06:55 PM
mattpolantz's Avatar
mattpolantz
Default Re: How-To: Install an Aftermarket Stereo
I picked up a Ducati Multistrada. I figured the maintenance costs of a German vehicle were too low, so I decided to go Italian. She has the best looking a** of any bike I've seen, but has a butter face...much like many of the women in my life.
1) I can't find a shot of the back of the N-1 for where you hook up the antenna. It's pretty obvious if you compare how the two of them fit together. You insert the male adapter into a hole in the new unit. The female adapter is on the receiving end of things.
2) Just hook up everything like I pictured. You don't need to mess with the amp at all. When I was done hooking everything up the bass hit hard enough to rattle my side mirrors a good bit, which the stock head unit could barely do. That should be enough bass for you. If it isn't then you need a lot more hardware than the head unit.
