Re: Braided Steel Brake lines... Where to Buy!?
HDDP, I was reading an earlier post on bleeding the brake lines and you said, "It's a two person job in this order RR, LR, RF, LF. Make sure you tell your assistant not to pump the pedal." I've only done brakes on friends cars and I’m just wondering why it’s a two man job if the other man isn’t pumping? Also is there anything else I should know?
I already ordered ATE Super Blue brake fluid.
Thanks!
