Braided Steel Brake lines... Where to Buy!?
Old Aug 21, 2007 | 09:08 AM
spensley's Avatar
Default Re: Braided Steel Brake lines... Where to Buy!?
Do a search on ebay for SLK320 brake lines.
There's a guy in Canada selling them for about $68 (USD).
I posted the link a couple of weeks ago.
Old Aug 21, 2007 | 12:23 PM
CrossfireLTD's Avatar
Cool Re: Braided Steel Brake lines... Where to Buy!?
I contacted the Ebay seller and he said they will not fit our Crossfires, not sure if this true or not.
Old Aug 21, 2007 | 01:00 PM
apkano's Avatar
Life is random...so am I.
Originally Posted by 04Fire
HDDP, I was reading an earlier post on bleeding the brake lines and you said, "It's a two person job in this order RR, LR, RF, LF. Make sure you tell your assistant not to pump the pedal." I've only done brakes on friends cars and I’m just wondering why it’s a two man job if the other man isn’t pumping? Also is there anything else I should know?
I already ordered ATE Super Blue brake fluid.
Thanks!
Is there any reason you can't use a mityvac? I've always found it easier than the old fashioned "push the pedal" method. (inevitably someone always lets their foot off the pedal before the bleeder is sealed)!
Old Aug 21, 2007 | 01:09 PM
04Fire's Avatar
I don't see why not.
I did the push pedal method because I don't have a pressure bleeder or mityvac...
PNA
Aug 30, 2024 02:06 PM
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
frogwash
Aug 14, 2015 03:44 PM
PNA
Jul 27, 2015 12:28 PM
