Old Aug 21, 2007 | 01:00 PM
apkano's Avatar
apkano
Life is random...so am I.
Default Re: Braided Steel Brake lines... Where to Buy!?
Originally Posted by 04Fire
HDDP, I was reading an earlier post on bleeding the brake lines and you said, "It's a two person job in this order RR, LR, RF, LF. Make sure you tell your assistant not to pump the pedal." I've only done brakes on friends cars and I’m just wondering why it’s a two man job if the other man isn’t pumping? Also is there anything else I should know?
I already ordered ATE Super Blue brake fluid.
Thanks!
Is there any reason you can't use a mityvac? I've always found it easier than the old fashioned "push the pedal" method. (inevitably someone always lets their foot off the pedal before the bleeder is sealed)!
