Thread: ECU Performance
Old Jul 9, 2007 | 04:11 AM
HDDP's Avatar
HDDP
Default Re: ECU Performance
Originally Posted by MMZ_TimeLord
Ouch... a bit pricey, but has a wide range of applications... I had seen this before, but I didn't look a lot further as I was hoping for a more open source solution. *Sigh*
$2,000 is pricey...
That's exactly why I'm looking at a piggyback system that will provide me fully adjustable tuning capabilities for less than $1,300... And as I add modifications, cams, etc. I can readjust and re-tune...
Who needs to reflash the ECU when all you need to do is adjust the FAM and timing downstream of the PCM and ECU... That's all that the aftermarket performance chips achieve, but they are selling you only 1 off-the-shelf map that has nothing to do with your specific car or performance needs...
And who wants to risk reprogramming the computer that operates their car without some serious education about the process...
The great thing about a piggyback system is that you can disconnect it and your car computer is still OEM...
