Re: Automatic Headlights
I believe that to get the DRL function you have to replace the entire headlight switch with a Canada-spec one. This was discussed not too long ago so you might want to do a search.
The Crossfire, unlike many other cars out there, does not come pre-wired for all the options. If the option was not installed at the factory chances are the wiring will not be there for it.
Search the forum for threads on installing the rear fog light on US-spec models or installing fog lights on a base coupe.
