Automatic Headlights
Old Nov 6, 2014 | 07:45 AM
Default Re: Automatic Headlights
Then I would think the simplest way would be with a N/O relay driven by start/run voltage and supplying fused 12v to whatever circuit for the lights you want to come on with the ignition.
Wire, relay, fuses should be less than $10 US.
( you could run the start/run 12v going to the relay through a switch also, that would allow you the choice of having DRL's or not )
Old Nov 6, 2014 | 07:47 AM
Originally Posted by Mrmiata
"Automatic" DRL's - yes.. there is a terminal in the fuse box by the brake master cylinder that is "key on hot".. I'm planning on adding a Normally closed relay to the DRL's I'm adding that will open the circuit when headlights are turned on.
Nokke: what mrmiata is reffering to is a US ( or Oklahoma ) law that requires DRL's to be OFF when headlights are ON. May not apply in Finland.
Old Nov 6, 2014 | 07:48 AM
Mrmiata's Avatar
BUT... LOL.. you do realize factory DRL's go off with headlights on..
Old Nov 6, 2014 | 07:49 AM
Mrmiata's Avatar
Dang.. you must have double dosed on the coffee this morning... YOUR FAST TODAY! lol
Old Nov 6, 2014 | 07:51 AM
With 180 on Sabbatical, someone's gotta keep an eye on you.
Old Nov 6, 2014 | 07:53 AM
Mrmiata's Avatar
He didn't etch a stone or anything saying when he was coming down from the mountain did he?
Old Nov 6, 2014 | 08:30 AM
Nokke's Avatar
Same here, so DRL's need to turn off, when headlights are on..
Thanks for this also, need to check this closer.
How hard it is to get DRLs turn off when headlights are turned on? Need it new light-switch?
Am I trying totally impossible?
Old Nov 6, 2014 | 08:35 AM
Mrmiata's Avatar
A "normally closed" relay with a key on hot supply will turn on DRLS anytime the ignition is turned on. I haven't checked but planning on tapping the headlight fuse if its "downstream" of the headlight switch for power to "open" the relay to turn them off. If not I will directly tap the headlight hot lead.
Old Nov 6, 2014 | 09:23 AM
Nokke's Avatar
Ok. thx.
Let me know Your result.
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Selbyl
Sep 22, 2015 10:41 PM
atdavis2
Sep 21, 2015 01:25 PM
