Thread: ECU Performance
Old Jul 15, 2007 | 10:55 PM
  #39 (permalink)
Maxwell's Avatar
Maxwell
Default Re: ECU Performance
Originally Posted by woody
It should be quite possible to hack the lateral G sensor module (under the dash) to feed it a modified signal. The Crossfire uses a mass/spring type sensor with an analogue output, (rather than a solid-state accelerometer) The system would be just the same a 'sprint booster'; an A-D converter to digitize the output of the sensor, into a small micro (PIC/AVR etc.) to generate the desired output via a D-A converter based on a look up table or formula. I built something similar to create a variable response throttle pedal module. In fact you can do it with a single chip and some support circuitry. As ever its a bit more complicated that since the system also takes a signal from a steering angle sensor.
I'll see if I can plot the response curve of the G sensor when I get chance like I did for the throttle pedal (attached).
Very cool stuff indeed, If you can build a separate ecu to manage the electronic brakes that would be, Out of this world as far as handling upgrades! To be able to choose different maps for which brakes can activates with-in certain steering angles and g-loads, I think the guys at NASA are gonna start making new rules for HDDP.
