Old Apr 27, 2004 | 12:33 PM
Heb80's Avatar
Heb80
Default
I did this same thing with my Stratus R/T when I moved from NY to PA and no longer required a front plate. You can pick up the plugs at places like Home Depot or Lowes too. Just make sure you scuff them up a bit before you paint them or else the paint will start to come off after time. Rain hitting the front of a car at 75mph does have some force.
Originally Posted by drunkiq
I just removed mine and panted the plugs I used to match the car... it cam out looking pretty good.
I was at the auto store picking up a new mit to clean the car and wondered if I could find something to fit in the holes. I found a box of various sized interior panel plugs (the plastic ones that have the smooth round outside that you have to use a thin pice of metal to remove) for chrysler vechicles. I also ran over to the spray paint section and grabed the one that I thougt looked closet (it was called graphite).
I found two differnt ones. one had a dimple in the middle so I went with the smooth version. I had to change the dimeter of the screw part with a utility knife and chop off the tip becase it was to long and was touching something.
I had an extra set of these so I figured I would experiment with them and then make the final pair when I had more time and the weather was better for painting projects.
Well I shot it with plastic primer, then some of the paint I bought and then I clear coated it.
It actually looks good and fits tight into the holes the dealership made in my poor bumper. When the weather is dry I will cut the other exact pair to fit and then paint the correctly.
I have a crummy pic (I only have a camera phone). I will try to see if i can do a gallery thing here and put it up.
-marc
