Originally Posted by Coyote
Also, it should be noted that after replacing the EGR valve, the car seems
quite a bit more responsive. Just barely pressing on the gas pedal seems
to make the car want to jump up and go...
Coyote
Hi Coyote, just wondering if the dealer was able to diagnose the problem and get any codes, as mine ran great after replacing the IC aux water pump, but now the punch is just not there and I just put in new k&N filters. Do you know anyone that has separated out the IC cooling system from the main and run two separate systems? Thanks.
