EGR Valve problem?
Old Apr 19, 2006 | 10:51 PM
T.Crammer's Avatar
Default Re: EGR Valve problem?
What was the cost for the EGR Valve replacement? Did you do this yourself?
Old Apr 20, 2006 | 10:11 PM
Coyote's Avatar
Everything was covered under warranty. I had no charges for this work.
Coyote
Old Apr 25, 2006 | 01:01 PM
GoodEnough's Avatar
My guys at the shop haven't been able to duplicate/experience the lunging or bogging when the supercharger doesn't engage. I will print this info on the secondary water pump & hope they'll take me seriously. Thanks again for sharing.
Old Apr 25, 2006 | 03:42 PM
FirebaseD's Avatar
So was it and EGR Valve problem or a SC over heating problem, with SC water pump replacement?
Who told you it was an EGR problem from the get go?
Old Apr 28, 2006 | 11:10 AM
Coyote's Avatar
The problem was the auxiliary water pump for the intercooler. This
caused an overtemp shutdown of the SC. Once replaced the problem
was resolved.
The service department at the dealership told me initially that it was an
EGR problem, as they had seen a code for this from the OBD.
Coyote
Old Apr 29, 2006 | 11:49 PM
FirebaseD's Avatar
Makes me wonder why the code came up on the computer read out. Should be no code if the problem did not exist, something to think about. Hooah.
Old May 2, 2006 | 03:08 PM
cudaman's Avatar
Any mention by any of those dealerships whether the intercooler water pump change was a TSB related problem? Seems that at least a few of you have the same IC cut-out issue... Also, for those affected, by chance could you post your individual build dates? Could be related to a given build date that may or may not be under a current TSB.
I'm new on this forum and we had the E-19 done. Haven't yet (nor hope to) have the IC-water-pump issue. Our build date is 8/2004 for our 2005 SRT-6. Wife drives the car mostly... She wouldn't know the difference. I will have to take it out for hard spin now that summer approaches to see if the supercharger cuts out from this overtemp condition on the IC. Thanks.
Old Aug 20, 2007 | 01:28 PM
rlynes's Avatar
Also, it should be noted that after replacing the EGR valve, the car seems
quite a bit more responsive. Just barely pressing on the gas pedal seems
to make the car want to jump up and go...
Coyote
Hi Coyote, just wondering if the dealer was able to diagnose the problem and get any codes, as mine ran great after replacing the IC aux water pump, but now the punch is just not there and I just put in new k&N filters. Do you know anyone that has separated out the IC cooling system from the main and run two separate systems? Thanks.
Old Aug 20, 2007 | 05:15 PM
Coyote's Avatar
rlynes,
The codes were not reported to me, so I do not have them to provide. Sorry about that. As for the "punch" being gone, have you tried resetting
the driver profile? The procedure for doing this has been posted often,
but to save you the time...
With engine off...
Ignition key to the "run" position
Press the accelerator pedal to the floor and hold for 5 seconds
Ignition key to the "off" position
Remove pressure from the accelerator pedal.
wait 2 minutes
Over time the electronic brain builds a profile of your driving style and
adjusts shift points, etc to what it feels is correct for your driving behavior.
Myself, I drive the **** out of the car, but I still find myself resetting the
profile back to defaults fairly often due to the "rush hour" traffic I have
to endure each morning and evening.
As for knowing of anyone who has separated the cooling systems, I'm
afraid I do not. Sorry I can't help there. But, if you take on this project,
please keep the group informed.
Coyote
minimayhem
16
Aug 23, 2016 07:47 AM
nataliefs
Oct 5, 2015 01:03 PM
skeet370
29
Sep 18, 2015 05:53 AM
steps
Sep 12, 2015 09:23 PM
rdougc
Sep 5, 2015 10:30 PM
