Old Aug 22, 2007 | 11:55 AM
FreetailScott's Avatar
FreetailScott
Default Re: How-To: Install an Aftermarket Stereo
Originally Posted by peter_k
Any brand will work, doesn't have to be Scosche... Can be Metra, Best Kits, etc...
If you do a search, I posted up on using RCA's and splicing in at the factory amp in order to get subwoofer control and better sound Q from the fronts.
The RCA harness that they showed you, won't have any real benefit over speaker level other than some better sound quality... BUT you need to have a deck with a high Volt Pre-out (like 4 Volts and up) to properly get the same volume out of the amp...
Thanks Peter, that clears things up!
