Old Aug 24, 2007 | 06:34 AM
  #45 (permalink)
malcb's Avatar
malcb
Default Re: Fuel Injectors / Rail
Tireless as usual in your endeavors to promote the Crossfire HDDP. Not fair I thought someone else had done something and I had found it!
Anyone got any comments on the injector sizing calcs?
Notice that at 6,000 rpm, you have 100 revs per second, 1 firing per 2 cycles, is 1/50 of a second or 0.02 second for two strokes. Injector open time is 0.017 with 20 lb injectors (80% duty). Seems to add up to 100% duty with 17 lb! ie injectors open all the time?
Just goes to show how little benefit sequenced injection is once you get to the higher rpm's.
Malcolm
