Fuel Injectors / Rail
Old Jul 12, 2009 | 12:56 PM
  #141 (permalink)
ChuckNorris's Avatar
Default Re: Fuel Injectors / Rail
These are the same ones I used. 8 for 108 bucks with shipping.
* Fuel Injectors 19lb Design III 3 Ford Mustang TPI BMW:eBay Motors (item 280366523544 end time Jul-12-09 17:52:45 PDT)
Old Jul 12, 2009 | 04:52 PM
  #142 (permalink)
downwardspiral's Avatar
Originally Posted by ChuckNorris
Looks like the part number 0 280 155 700, thanks Chuck!
(Part number)................................... Ohm's.....cc rate....... lb rate
0280 155 700..........................................14.2....... 204...............19
Old Jul 13, 2009 | 01:34 AM
  #143 (permalink)
jetman's Avatar
Hi,what size spacers do we need for this injectors? Thanks for the part#
Old Jul 13, 2009 | 12:46 PM
  #144 (permalink)
JimmySkullz's Avatar
Do you need a tune with those, or is it a set up the computer could adjust to?
think these injectors, C.A.I. and 74mm throttle body would be a decent set up?
Old Jul 13, 2009 | 01:02 PM
  #145 (permalink)
The injectors, cai and the TB would be a very good setup with a tune. The only time bigger injectors make more power is when the stock ones are maxed out because of changes in airflow. The intake and throttle body will flow more air through the motor, the injectors and tune will give you a better air fuel ratio.
Old Aug 21, 2009 | 03:32 AM
  #146 (permalink)
peter_k's Avatar
Thanks for the part number Chuck...
Old Aug 21, 2009 | 08:09 PM
  #147 (permalink)
waldig's Avatar
Talking Re: Fuel Injectors / Rail
BIGGER INJECTORS ARE NOT NEEDED.
I went from 17 to 1 f/a ratio to 9 to 1 just be changing the rail pressure.
I did a big writeup showing the results and method to increase the pressure. THe stock regulator has a port that will accept a pressure signal and increase the rail pressure.
I went to 80 psig rail on 20+ psi boost, way too much.
Fuel falls off with higher boost due to the INCREASED boost PUSHING against the injector DECREASING the pressure differential. At idle the 58psig fuel rail is aided by the -10 psig of the intake manifold to give an effective 68 psig differential.
By adjusting the rail pressure I have been producing f/a ratios of about 12.7. I control that DYNAMICALLY by monitoring the f/a ratio WHILE DRIVING with a add on computer. See my signature for coming events............
YOu dont need bigger injectors and I have been to 25 psi boost ratings before I ditched the code three / 178 and went to a STANDARD 185 eurocharged pulley.
WOODY
Old Aug 21, 2009 | 08:30 PM
  #148 (permalink)
The injectors are for naturally aspirated crossfires with intake mods. I calculated 19.4 #hr injectors are needed for 215hp at .80 duty cycle and .50 BSFC and 58psi fuel pressure on
http://www.rceng.com/technical.aspx
The OEM injectors are calculated to be at 100% duty cycle to produce the factory advertised 215 hp, IMO this is why the stock xfire falls flat in the upper RPMs. My car definately pulls harder from 4000-6200 rpm after switching the injectors.
The calculator may be off but I believe it to be accurate.
Old Aug 22, 2009 | 11:09 AM
  #149 (permalink)
RC Fuel Injection
Did you tune your crossfire or is it still have a stock flash?
Old Aug 22, 2009 | 02:15 PM
  #150 (permalink)
Stock programming
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 25, 2015 02:16 AM
Sep 23, 2015 09:14 AM
04Fire
Sep 15, 2015 07:40 PM
