Old Jul 13, 2009 | 01:02 PM
  #145 (permalink)
downwardspiral's Avatar
downwardspiral
Default Re: Fuel Injectors / Rail
Originally Posted by JimmySkullz
Do you need a tune with those, or is it a set up the computer could adjust to?
think these injectors, C.A.I. and 74mm throttle body would be a decent set up?
The injectors, cai and the TB would be a very good setup with a tune. The only time bigger injectors make more power is when the stock ones are maxed out because of changes in airflow. The intake and throttle body will flow more air through the motor, the injectors and tune will give you a better air fuel ratio.
