Old Aug 22, 2009 | 11:09 AM
  #149 (permalink)
JimmySkullz's Avatar
JimmySkullz
Default Re: Fuel Injectors / Rail
Originally Posted by ChuckNorris
The injectors are for naturally aspirated crossfires with intake mods. I calculated 19.4 #hr injectors are needed for 215hp at .80 duty cycle and .50 BSFC and 58psi fuel pressure on
RC Fuel Injection
The OEM injectors are calculated to be at 100% duty cycle to produce the factory advertised 215 hp, IMO this is why the stock xfire falls flat in the upper RPMs. My car definately pulls harder from 4000-6200 rpm after switching the injectors.
The calculator may be off but I believe it to be accurate.
Did you tune your crossfire or is it still have a stock flash?
