Old Aug 21, 2009 | 08:30 PM
  #148 (permalink)
ChuckNorris's Avatar
ChuckNorris
Default Re: Fuel Injectors / Rail
The injectors are for naturally aspirated crossfires with intake mods. I calculated 19.4 #hr injectors are needed for 215hp at .80 duty cycle and .50 BSFC and 58psi fuel pressure on
http://www.rceng.com/technical.aspx
The OEM injectors are calculated to be at 100% duty cycle to produce the factory advertised 215 hp, IMO this is why the stock xfire falls flat in the upper RPMs. My car definately pulls harder from 4000-6200 rpm after switching the injectors.
The calculator may be off but I believe it to be accurate.
