Thread: Disabling TC
Old Aug 24, 2007 | 10:12 PM
apkano's Avatar
apkano
Life is random...so am I.
Default Re: Disabling TC
Originally Posted by fortknox82
I finally had the time to do your little test.
In neutral standing still my 2006 base coupe will not go over 4,300 rpm. This is when all fuses are in, when only 18 is pulled, and when 17 & 18 are pulled.
Now when fuse 18 is only pulled the orange abs and bas lights come on and the traction control cant be turned on or off. I can rev it up and drop the clutch and it will burn rubber as long as it can and chirp second hard. No signs of any TC. If i pull 17 & 18 there is no difference in launching.
Now as far as getting to redline in both instances I CAN. Pulls all the way hard with no problems.
Kind of weird that it wont let me rev past 4,300 EVER but i can run it to redline no matter what.
So what do you all think about that. Bone stock.
I can push the little button on the dash...rev it up, dump the clutch and spin 'em for a few feet, powershift 2nd and chirp 'em hard, powershift 3rd and chirp 'em. All without pulling a fuse, WHY would I want to give up 1,500 rpm?
In my (albeit limited) time on this forum, there's 2 things you can count on...HDDP knows more about Crossfires mechanicals than you, and Andrew knows more about keeping Crossfires clean than you!
Maybe I'm wrong...but I don't think so!
