Old Aug 29, 2007 | 06:55 PM
NeverEnough's Avatar
NeverEnough
Default Re: How-To: Install an Aftermarket Stereo
Ok, to make a long story short. Last night I was installing my headunit in the SRT-6. I wired everything up as described in the how-to and that went fine. The radio works perfect and looks great with the dash. The problem is with the "sleeve" that you slide the headunit into. The sleeve obviously has little tabs that are supposed to be used to secure the sleeve in the dash opening... Well this particular one has NO TABS that line up with any of the of the Dash opening. The opening is COMPLETELY smooth except for where the factory radio locks to it. In the How-To it's mentioned that there is a place at the top of the opening that can be used for these tabs, but no dice here. So basically, the Headunit is just kinda sitting there and wont stay in the dash. Not to mention you can pull it right out with no effort. I took it a stereo shop near where I work, and they couldn't help either. I would try a different sleeve, but it has to be one specific to this headunit because of the way it locks into it...
Has anyone else had this problem?
