Here is what I came up with in a search on tirerack.com
http://www.dfwsbr.com/crossfire/tech..._crossfire.pdf
Discount tire showed no matches for the Crossfire, however I'm sure they can order the tires listed as options on tirerack. They can also match / beat prices they offer on tirerack.com
Looks like a few michelins / contentinals are available. Look at tread wear, wet / dry traction for key features. Since you won't be seeing snow, you might not want to go with all season as they tend not to stick as much. But with that you will probably loose tread wear life. Meaning you'll replace them more often. You can also factor in cost of tires =)
Good luck. Let us know what you pick.
