Old Sep 5, 2007 | 11:56 AM
Steve Hellums's Avatar
Steve Hellums
Question TPM Low Tire Light
Well I'm running my car with out sensor's and just figured I would pull the warning bulb. I looked in the service manual on how to remove the instrument cluster, it say's first remove the steering wheel and that's about as far as I went on that route. So I started looking into the wiring to see if it was possible to just pull a wire to get the light to go out, I don't think you can just pull the fuse because I believe it's shared with the Home Link System. In the wiring details the module applies a ground to turn the light on, but it also looks like there could be a problem disconnecting the wire because it said something about a body module in there somewhere if I remember correctly. So with all that crap being said, has anyone disconnected this bulb some how?
