Old May 4, 2004 | 11:02 PM
  #47 (permalink)
DFWSBR's Avatar
DFWSBR
Default
I'd say just have it removed and put back on. Chances are the clips aren't set in place properly.
You need a very small torx bit to remove the metal retainer in the door jam. 3 of those screws are there. Once that is off you can remove a phillips screw located just beyond the belt in the slot. Then that entire plastic part by the small window just lifts up with some effort.
I'd personally have a dealership do it so you don't snap any parts off
