Originally Posted by Maxwell
first of all the easiest part of the whole project is doing the engine swap, the hardest part is not finding the part,s but getting all the computers to jive. The bosch ecus are not tuner friendly unless your working on a vw or audi. Maybe Startech can help you out with re programming the ecu, but I don't think that's the business they are into. Good luck on your mission, that is if you choose to accept it!
Maxwell, I think i have mentioned this a couple of times but I will try to be more clear. Any engine I use will have the original computer that was meant for it. When you swap modern engines you need the engine, engine wiring harness and ECU. I will not be trying to adapt my stock ECU to a V8 or any other engine.
