Let's talk power!
Old Sep 23, 2007 | 11:35 PM
  #41 (permalink)
Mr. F's Avatar
Default Re: Let's talk power!
i've seen pics of Burnsville's work on some Jeep sites, looks like they do great work.
Old Sep 23, 2007 | 11:36 PM
  #42 (permalink)
Mr. F's Avatar
I have also had friends take the Ford SHO V6 and turn it north south and put it in street rods. This was an amazing looking engine that was actually built by Yamaha.
the SHO motors could be bolted up to Aerostar transmissions...
Old Sep 24, 2007 | 08:01 AM
  #43 (permalink)
LantanaTX's Avatar
Originally Posted by ApocMan
In addition, being diagnosed in the past weeks with a rare form of bone marrow disorder that is can turn into a form of Leukemia and mostly found in men over 60, I'm 35 so I'm been tired a lot more than normal, but I'm still excited about working hand in hand with Lantana on making our dreams come true.
Hey, I hope you are going to be OK.
I have been doing the research and am leaning towards the V8. I am taking engine measurements off a friends E500. It appears this could be an easy swap. I also studied photos of the Startech V8 and nothing along the sides or rear of the engine appears to have been moved or altered. It does appear to to have a fan/shroud from a C43. The only other thing that might be needed is exhaust manifolds and engine mounts from the C43, but not sure about this yet.
Old Sep 24, 2007 | 09:08 AM
  #44 (permalink)
The Toy's Avatar
I still think the 3.2 CDI would be a great choice. 220 hp and 400 Ft pd of torque stock. Bolt that in with the 7 speed auto and it should be a tire shredding machine.
Old Sep 24, 2007 | 09:29 AM
  #45 (permalink)
msheredy's Avatar
Originally Posted by GatorLCA
It's too bad the SRT-4 engine only comes in a FWD flavor. If it could be done to switch it to a RWD then that would be your best option since the A/M is huge for that engine.
I was thinking the same thing. Back when the imports were really taking off I was working at a chassis fabrication shop where they took a Honda Prelude rotated the motor 90º and put a reverse rotation Lenco transmission in it. The car was a full tube chassis with some damn huge slicks outback with a Ford nine inch. It can be done although I would like to see if some other transmission could be used because those Lencos are huge, expensive and not very street friendly.
Originally Posted by Maxwell
...even boosted to 14 psi I'm not sure it will have all that fun torque of a boosted v6.
I haven't driven one but after seeing what this engine can do with some simple bolt on stuff I'm going to have to disagree with you. Here is a good example of what can be done. This little engine cranks out 700 hp!
Old Sep 24, 2007 | 12:16 PM
  #46 (permalink)
LantanaTX's Avatar
Unless I come up against a major problem that I can't resolve, I am going with one of the Mercedes 24 valve V8's. In order of preference they are 55 AMG, 500, C43. 430.
320 215 HP 229 foot Lbs Torque (Stock)
430 275 HP 295 " "
C43 302 HP 302 " "
500 302 HP 339 " "
C55 342 HP 376 " "
An ECU re-flash will add 20-25 HP to any of these engines (provided I can get 93 octane). Cams can add another 25 HP.
The weight difference from the V6 is 130 lbs.
Old Sep 24, 2007 | 01:38 PM
  #47 (permalink)
ApocMan's Avatar
I have been doing the research and am leaning towards the V8. I am taking engine measurements off a friends E500. It appears this could be an easy swap. I also studied photos of the Startech V8 and nothing along the sides or rear of the engine appears to have been moved or altered. It does appear to have a fan/shroud from a C43. The only other thing that might be needed is exhaust manifolds and engine mounts from the C43, but not sure about this yet.
I'm praying to Christ I will be ok and live a long and healthy life. I got a wife and two kids and I want to be able to live long enough to help raise my grand children.
So when we going to get together and work some Crossfire Magic...
I'll try and give you a call tonight...
Old Sep 24, 2007 | 01:57 PM
  #48 (permalink)
RPM's Avatar
RPM
Moderator
In addition, being diagnosed in the past weeks with a rare form of bone marrow disorder that can turn into a form of Leukemia and mostly found in men over 60, I'm 35 so I'm been tired a lot more than normal
I wish you the best. Stay strong.
Old Sep 24, 2007 | 04:09 PM
  #49 (permalink)
bollox's Avatar
Done some research... good E430 80K >= £8000 ($1,600 USD). I could run it for a while then use it... however would not want to be the first transplant (me chicken ****).
Old Sep 24, 2007 | 04:25 PM
  #50 (permalink)
LantanaTX's Avatar
Originally Posted by bollox
Done some research.... good E430 80K >= £8000 ($1600 USD). I could run it for a while then use it... however would not want to be the first transplant (me chicken ****).
Me not chicken ****, Me just need to steal motor (a very good bargain), this way if anything goes wrong I can still bail and not lose any money. $1,600 US for a E430 engine would be right in the ball park but 8,000 GBP is more like $16,000 USD, you meant 800 GBP's right?
Apr 28, 2016 02:04 AM
o55ie18
Oct 5, 2015 05:50 PM
Mackel
Sep 29, 2015 02:41 PM
JEFASOLD
Sep 28, 2015 12:10 PM
Valk
Sep 17, 2015 11:43 AM
