Old Sep 24, 2007 | 09:29 AM
  #45 (permalink)
msheredy's Avatar
msheredy
Default Re: Let's talk power!
Originally Posted by GatorLCA
It's too bad the SRT-4 engine only comes in a FWD flavor. If it could be done to switch it to a RWD then that would be your best option since the A/M is huge for that engine.
I was thinking the same thing. Back when the imports were really taking off I was working at a chassis fabrication shop where they took a Honda Prelude rotated the motor 90º and put a reverse rotation Lenco transmission in it. The car was a full tube chassis with some damn huge slicks outback with a Ford nine inch. It can be done although I would like to see if some other transmission could be used because those Lencos are huge, expensive and not very street friendly.
Originally Posted by Maxwell
...even boosted to 14 psi I'm not sure it will have all that fun torque of a boosted v6.
I haven't driven one but after seeing what this engine can do with some simple bolt on stuff I'm going to have to disagree with you. Here is a good example of what can be done. This little engine cranks out 700 hp!
