Re: 19/20 inches wheels
I went with a 20x9.5 35mm in the rear and a 19x8.5 25mm in the front and had it lowered with the Eibach kit, and ran a spacer in the rear. I traded it In so all i have is the pictures of it at the dealership but I hope it helps. Watch your tire height though that’s where you run into problems. Cyril can tell you that. There was a great thread on how his tires were getting eaten up and a bolt that you may need to shave. You do not want to run anything bigger then a 35 in the rear and a 25 in the front. Call discount tire they will tell you the largest you can go with those rims.
