Old Sep 29, 2007 | 12:42 PM
  #72 (permalink)
Maxwell's Avatar
Maxwell
Default Re: Fuel Injectors / Rail
Originally Posted by Cincinnati Slim
Sounds like we're starting to reach a consensus here; going to an injector set with a MODERATELY LARGER flow rate should slightly richen things up and improve Open-loop high load (hard acceleration) power particularly in conjunction with increased airflow (bigger cams, intake, filters, bigger air boxes, headers, higher flow/removed/gutted cats, free flowing exhaust etc).
So here's the $ 64,000 question...what is the OEM Mercedes or Bosch part number for a compatible injector which will deliver a 15%-20% flow rate increase ?
Do the injectors in some of the Mercedes Models equipped with the 3.2 SOHC motor flow more?
And isn't there a 3.5 version of the SOHC V6 used in SUVs ? I bet those injectors would work and deliver a little extra fuel!
Let me know what to look for and I'll try to find a working "junkyard sourced" set to try.
Cincinnati Slim
I would just stick with the SRT6 injectors, but I guess if you want to go nuts you could try the SLK55 injectors, or maybe the 4 liter v8 benz injectors.
